Large drum backplates
Ems
Are you only after a pair as the adjusters had seized?
If so, I found that getting them cherry red with a blowtorch had mine moving in no time - and my car had been sitting dormant for about 19 years...
Good luck either way!
Understood.
I heated them with a blowtorch, then cooled quickly with a water sprayer - alternate with more heat, more water etc - you get the picture...
The shock of the heat and rapid cooling will cause them to give up the fight pretty quickly.
Hope that helps!
On 29/09/2018 at 20:48, Ems said:
Does anyone have a pair of early Manta B/C drum backplates with manual adjusters that haven't seized?
Thanks
I have the full set up here after converting to discs if you're still looking?
