Side repeater removal.
H11poc
Two flat heads to remove the lense
Two pozi heads that holds the metal to the wing and earths the light
Then when the unit is hanging on the wire, remove the bulb and then with a flat head screw driver push the tabs back from the fitting that hold the fitting to the metal plate so you can pass the wire through the hole.
