marksmanta Posted April 7, 2018 Share Posted April 7, 2018 Hi,still cant get manta to run, I have new pump that is pumping well,I have feed and return correct way round,I have checked timing,I have changed fuel pressure reg,I have changed injector control module,I have a good spark at each plug,I have put a new fuel pump relay on,The car will fire once then it wont fire again,were do injectors get there signal to inject fuel from as it seems to be starved of fuel after initial fire.can any body give me any more advice this would be much appreciated as shows are coming and manta still not running.GT/E 2.0 1985 HATCH Thanks Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 7, 2018 Share Posted April 7, 2018 (edited) . Edited April 7, 2018 by Snowy Quote Link to comment Share on other sites More sharing options...
Shug Posted April 7, 2018 Share Posted April 7, 2018 Are you certain it's not injecting fuel? I had similar issue with mine and it was because the injectors weren't pulsing and were permanently on so engine was getting flooded. No idea what the problem was tho as after replacing ecu and that not fixing it I ripped it all out and put megasquirt in. Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted April 7, 2018 Share Posted April 7, 2018 ECU issue I would say. Had this a few times now and it appears to be getting more common. Quote Link to comment Share on other sites More sharing options...
