Sie willetts Posted March 21, 2018 Share Posted March 21, 2018 Hi does anyone know if A series manta 1973 and manta b 1978 us same front disc calliper regards sie Quote Link to comment Share on other sites More sharing options...
1900SR Posted March 22, 2018 Share Posted March 22, 2018 (edited) The early Manta A used a smaller caliper. The early B caliper can be fitted, along with the bigger discs. Edit, I've got a feeling Simon P has run into problems with the original Rostyle wheels fouling early B series calipers so it may pay you to get your original calipers refurbed unless you are changing wheels as well and want bigger discs, although my car is running the bigger discs and calipers without issue. Dr Manta lists the same twinpot caliper for the A and the B with 246mm discs, early Manta A used 238mm discs i think. I hope all that helps. Edited March 22, 2018 by 1900SR Extra info. Quote Link to comment Share on other sites More sharing options...
Sie willetts Posted March 22, 2018 Author Share Posted March 22, 2018 Thanks already brought new 238 mom disc so did not want to make mistake I did think there was different since the brake pad looked different regards thank for you help sie willetts Quote Link to comment Share on other sites More sharing options...
