Kevin Abbott
Breaking cavalier centaur and manta hatch
Kevin Abbott Lots of B series parts on it.
Chrome trim from £20 a piece
2.0s engine £100
5 speed CIH box £100
3 piece spoiler £150 says manta 400 irmscher on the side
Irmscher rear bumper and infil panel £120
B series brake pressure valve £30
B series trim from £10 a piece
Clear coupe glass £25 each
4 and 5 speed centre console £30 each
Door trims in chrome £5 each
400 style door trim and fittings front and back £150
1800 early door panels and rear 1/4s £80
Centaur roof mechanism £200
Wings £40 each
Mk2 cav lights for some weird reason £40
B series rear lights £20
Lots of trim with the Opel sign on it from £10 a piece
Early loom £30
Carb tank £30
Rear panel £100
Rear 1/4s £100 each
Early suspension ( better handling ) full crossmember complete with upper and lower arms and stub axles £120
Front screen seal £50
Door seals in black £20
Trim in black from £10 a piece
Loads more from £10
Black door pockets all fixings sound £30 a pair
Mk1 can front panel very good apart from some slight rot on edges £120
B series seat belts including rear lap belts £100
Hatch spare wheel well £50
Good floor sections £40 a side. Front and rear
Hatch filler hole panel £30
B series scuttle panel. Requires some repair. Spare given with it so two for £100
Centaur back seat. £50
B series coil £30
Radiator £40
Manta front bumper ( can be cut and used as a splitter ) £30 I can cut it for you.
Heater boxes and motor £50
Early washer bottle and pump £30
Heater pipes £20
Full set of b series water hoses £20
Carb thermostat housing ( used with Weber carbs ) early one £30
Boot lid drilled for a 3 piece spoiler. Requires some repair £30
Black lower dash. Requires some repair but is hidden by the fuse box cover £30
Proper carpet boot carpet, not the vinyl rubbish one £30
Boot floor £75 with good spare wheel well
Black kick panels. Not the best but ok £20
Vauxhall wheel centres. 3 off. £20
Hatch rear 1/4 cards. Light grey. Good pair £40
Hatch roof skins. Non sunroof. £50 each
Hatch headlining. Good. Sunroof ones £50 each
B series front crossmember ( the best one for handling ) £120 complete
Rear axle with torque tube £120
Front brakes £40
 · Reply ·
1
 · 58 mins · Edited
Share this post
Link to post
Is the 5 speed still for sale and is it a gte box
Share this post
Link to post
Sorry to all waiting for parts or replies.
Im in holiday at the mo and will get back to it asap.
Cheers
  • Thanks 1
Share this post
Link to post
Ι need the set (4) of black grey door cards posted in 13121 Athens Greece . Do i have any chance ???
Share this post
Link to post
Hi Kev
Andy gave me the production number of the Centaur (sticker in glove box) but it was in the reply to a comment on FaceBroke, can't find it now :/
Any chance you could let me know and if possible the first date of registration off the logbook, I should be able to link it to the original reg from that
Cheers
Share this post
Link to post
Hi Kevin I'm interested in the engine. does it come with a carb? or is bare engine?
Regards Tom
Share this post
Link to post
Hi Tom. I think the engine is locked but we need to remove it for a look
Share this post
Link to post
Hi Kevin,
I'm interested in a N/S wing - are they / it still available and are they in reasonable condition?
White would be my preference, but certainly not essential.
Can you ship or is it collection only?
Thanks in advance.
Edited by IanMc
Share this post
Link to post
On 12/24/2017 at 14:47, Adrian watts said:
Do you have any panels for an 1987 hatchback? Or the boot carpet and lining?
If Kevin cannot help with these parts we may have panels and Hatch interior trim. What is it you require?
On 11/10/2017 at 16:53, IanMc said:
Hi Kevin,
Thanks in advance.
If Kevin cannot help with these parts we may have Some wings.
Share this post
Link to post
do you have any of the wiper relays?
regards sam
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
