jonayres
My everlasting GT/E hatch restoration
Share this post
Link to post
It's going to be a cracker once completed! Hopefully in 2018 then? :thumbup What's still to be done?
Share this post
Link to post
Hi, thank you. Yes, please let it be completed in 2018!!:rolleyes:
It always feels like it's getting close to completion. It still needs new fuel pipes to be fitted, the radiator and remaining hoses, the wiring will be examined and replaced if neccessary. It's got a brand new, exact original spec, stainless exhaust pipe to be fitted. The throttle cable housing and injectors, inlet manifold to go back on.
All of the fluids and oils to be put back, new spark plugs, leads etc. Finally, the new number plates which have been made with the original supplier's logo on them and a new set of tyres. I expect there's a few other things I've forgotten but not too much left now. It's been a very long process and much more expensive than I'd ever imagined. I've got photos of all the work completed - over 600 so far. The ours that have gone into this are amazing. It'll hopefully be as close to when it first left the factory as we can get it.
What are you driving? I guess a monaco blue exclusive?
Share this post
Link to post
All of the fluids and oils to be put back, new spark plugs, leads etc. Finally, the new number plates which have been made with the original supplier's logo on them and a new set of tyres. I expect there's a few other things I've forgotten but not too much left now. It's been a very long process and much more expensive than I'd ever imagined. I've got photos of all the work completed - over 600 so far. The hours that have gone into this are amazing. It'll hopefully be as close to when it first left the factory as we can get it.
That little lot shouldn't take too long. It's obviously a labour of love! I suppose it's finding the time to do it.
No, no Manta for me at the moment, but if I come in to a windfall that will change! I did run the attached Monaco Blue GTE for 12 years and 170K miles. Had it from cradle to grave. Couldn't afford to have the dreaded tinworm fixed as it was going to cost more than the car was worth at that time (1999). If only I had had the foresight! Sold for £75. I suspect it was reduced to parts thereafter.
Share this post
Link to post
As March passes us by, the painfully slow progress with this manta plods along. It'll be 4 years soon since this started. On inspection, the radiator had a small section of brass that had come loose. It was sent over to a radiator specialist for repair and texting before refitting it, Guess what? Upon pressure testing it was found to have a leak, so needed to be recored. Oh well, I was running out of excuses to spend some more money on this project, It is now refitted and looks very smart. With the manifolds fitted, that's another small step........
Share this post
Link to post
Years ago when i had a car with the 5 speed box it had a receipt in it saying gearbox oil replaced.they said they had used dexron2 fluid in it. Didnt question it at the time as i wasnt intending keeping it for long but it did perform ok in the time i had it (9month)
i afterwards asked my local garage about this and they said it would have been perfectly fine as the dexron was a high quality oil ?
How much longer would yhis have lasted or would it have been fine for ever ?
Share this post
Link to post
Hi, good question, I searched for the correct oil based on advice from Ian Virco, a very well established manta owner. It's one of those things. If I don't use it, it's damned sure to go bang and I can hear those immortal words....."I told you so."
Share this post
Link to post
 My red hatch had all the oils replaced not long before i aquired it, the gearbox had a quality brand oil ( the previous owner was a garage mechanic before retiring ), it did about 5k miles before the grearbox started making occasional odd noises in second gear, going to the south Yorkshire OMOC AGM it made a sudden terrible noise and then i'd only got 4th gear ( dirrect drive ) by the time i'd limped it home the gearbox was destroyed.
 Another Local owner did an XE conversion, put fresh quality brand oil in the gearbox at the time, that lasted about 5k before chewing it's cogs, he couldn't get another 1800 gearbox so i sold him a CIH gearbox and he had the front castings swopped over by a gearbox specialist, this time he used the correct Getrag Oil.
 Getrag gearbox oil is very different to normal gearbox oil, it's pink, relatively thin and smells of cherry aid ! if this is correct for Getrag boxes normal gearbox oil can't be right.
Share this post
Link to post
Get the original stuff. It' not expensive, in fact its about £8 for a litre. I bought mine from the dealer. I will see if I can pull out the part number. It does smell like cherry aid. The other thing is don't top up with other fluids as it doesn't mix. I always have a litre kicking around, but if your gearbox don't leak then you will prob never need it.
GM 93165290
Getrag 5 speed fluid
Edited by The General
Share this post
Link to post
On 9/9/2017 at 00:03, MANTAMAN said:
There is bound to be someone read this and come on here saying don't worry i put ordinary gearbox oil in mine and its OK, there might be some Getrag boxes that for reasons unknown will tolerate normal gearbox oil but ask yourself, are you going to chance it that yours is one of them ?
Good morning, here's a picture of it.
Share this post
Link to post
It now drives..... at last. Just a few finishing touches. Hopefully not long now!
Share this post
Link to post
And finally back on the road!!
On 27/09/2017 at 15:11, The General said:
We are going to have to get our Mantas together for a Photo at some point
She's back on the road at long last!!
  • Like 8
  • Thanks 1
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
