mantadoc Posted June 24, 2007 Share Posted June 24, 2007 (edited) Deleted Edited September 26, 2017 by mantadoc Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 30, 2007 Share Posted June 30, 2007 A battery shouldnt be to hard to get. Looks like another manta saved from the s c r a p y a r d ------------ Drift on!!!! Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 22, 2007 Share Posted July 22, 2007 The car is just about done now. Just need to find time to get it to an MOT station.. Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 1, 2007 Share Posted December 1, 2007 Got the timing cover back on today. Only the head left to do now. Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 23, 2007 Share Posted December 23, 2007 Finally had some time and put the head back on today. Got to start putting the parts needed to get it runing on fuel injection now. Question: Fuel lines inside the car or underneath. I'm going to be using 10mm copper pipe. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted December 23, 2007 Share Posted December 23, 2007 Use 8mm copper pipe, 10mm is a nightmare to bend. I'm thinking of running the fuel pipes inside on the mancona but it still sort of scares me. Kev Many A Night Tinkering About OMOC 4076 Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 24, 2007 Share Posted December 24, 2007 Ok, thanks for the advise. I will switch to 8mm copper pipe. I'm still not sure about running it inside the car but if i do it will be 100% copper with no joins inside. Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 28, 2007 Share Posted December 28, 2007 The engine is finally coming together.. Quote Link to comment Share on other sites More sharing options...
rutts Posted January 1, 2008 Share Posted January 1, 2008 glad you have stuck with doing the car, i was very tempted to buy it when it was for sale for an every day user for work. OMOC 5231 Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 2, 2008 Share Posted January 2, 2008 Cheers, only the fuel lines, oil, filter to be fitted and it will be ready to run...I hope. Still might sell the car, unsure yet... Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted January 2, 2008 Share Posted January 2, 2008 Looking very nice. I love the paint job on the engine, makes it look all the more special. [8D] ------------ Drift on!!!! OMOC 6081 Recovery work taken. Email for more details Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 3, 2008 Share Posted January 3, 2008 New fuel lines installed now. Does the fuel feed from the tank connect to the fuel pressure regulator on the fule rail or does it not matter which way around? Thanks Quote Link to comment Share on other sites More sharing options...
rutts Posted January 4, 2008 Share Posted January 4, 2008 pressure release is on return side i think, OMOC 5231 Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 4, 2008 Share Posted January 4, 2008 Well it lives now. After many hours of work it runs!!! Cant get the idle down below 1000rpm so think i may have an induction leak. Prime suspect is the injector seals as i had to re use the old ones. Tomorrow i'm going to check the: 1.Servo vacuum pipe. 2.Rocker box to inlet plenum pipe. 3.Airflow meter to plenum pipe - But this is brand new from OCP. 4.Dissy vacuum pipe. 5.Warm up regulator pipe work - i need new pipes but i dont think they are leaking. Can anyone suggest anything else? Thanks. Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 5, 2008 Share Posted January 5, 2008 The vacuum leak is down to a worn throttle spindle. Will need to re bush a spare one i have. I have just filled the voids with vasaline. But the car is now up and running. Small leak from the rocker cover gasket as i had to re use the old one. Quote Link to comment Share on other sites More sharing options...
paulmanta Posted January 5, 2008 Share Posted January 5, 2008 A job very well done, That looks like it has always been there and has not replaced an 1800 ! nice and neat and clean too. may be at Billing if you still have it ? Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted January 5, 2008 Share Posted January 5, 2008 What process did youuse to paint the engine? ------------ Drift on!!!! OMOC 6081 Recovery work taken. Email for more details Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 5, 2008 Share Posted January 5, 2008 I wanted it to look original. I've even spliced in the proper plug to connect the fuel injection loom in. Still needs tidying up though. To paint the engine i just cleaned everything with parafin and then brush painted it with engine enamel. Just make sure you clean all the old oil and gunk off or it wont stick. Would it be worth wrtting up exactly how to do this conversion? Or would most people already know how to do this?? Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted January 5, 2008 Share Posted January 5, 2008 Well im about to put a 2.1 CIH and 5 speed gearbox into a b series that originally had a 1600 in it. It might help me abit! ------------ Drift on!!!! OMOC 6081 Recovery work taken. Email for more details Quote Link to comment Share on other sites More sharing options...
philips Posted January 5, 2008 Share Posted January 5, 2008 yes definatly,as i am doing the exact same conversion aswell,nice car btw Quote Link to comment Share on other sites More sharing options...
Snowy Posted January 5, 2008 Share Posted January 5, 2008 Ok. I will put something together and post it on the forum. Quote Link to comment Share on other sites More sharing options...
