rear axle 400r
peter evans
hi guys
just bought a manta 400r unfinished project rolling shell
car was a 4 speed what i need to know is the axle casing the same as a 5 speed can i have a lsd fitted in place of the original diff
Also whats the disc conversion set up what discs and calipers do i need and where t get handbrake cable?
 ill probably have more questions as the build comes along
thanks peter
Axle should be the same, assuming its the original from the car and the car was a 1600 or larger engine. If so you can get an LSD fitted, just remember there are 2 different types of diff one for the 3:44 ratio and one for the 3.67 or 3.9 ratios.
I've just finished a disc brake kit that will be available for sale very soon using mk4 astra calipers and discs
