611 Posted October 25, 2014 Share Posted October 25, 2014 Would there be any problems or issues if i move the steering rack forward an inch from the cross member on and A series? the position will be exactly the same as standard ie. bolted in to the cross member with the original bolt holes so the alignment would be the same, but just spaced forward to give me a bit of a better angle for the steering rod. Thanks Andy Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted October 25, 2014 Share Posted October 25, 2014 More turns lock to lock Quote Link to comment Share on other sites More sharing options...
611 Posted October 26, 2014 Author Share Posted October 26, 2014 Hey Paul Thanks for the info, if that's all that is effected then that's not too much of a problem. i have wide tyres on there anyway so the lock is not that great on a good day :-) Andy Quote Link to comment Share on other sites More sharing options...
bones Posted October 27, 2014 Share Posted October 27, 2014 I would have thought it would create bump steer problems? Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted October 27, 2014 Share Posted October 27, 2014 Bump steer would only be induced if you altered the angle of the steering arms, ie lowering the rack Quote Link to comment Share on other sites More sharing options...
611 Posted October 27, 2014 Author Share Posted October 27, 2014 Thanks for the info, i have decided to just buy a double steering joint as they can cope with up 70 degrees angle so that should save moving the rack. Bloody expensive to buy from the US. I had all the other parts but the single one looked to be a bit tight on the angle so i hope this will solve it!! Andy Quote Link to comment Share on other sites More sharing options...
mantadoc Posted October 28, 2014 Share Posted October 28, 2014 Will be messing up the geometry, Ackerman angle for instance. Lowering the rack and lowering the track rod ends how Mantaray did, for example, would not affect geometry Quote Link to comment Share on other sites More sharing options...
bones Posted October 28, 2014 Share Posted October 28, 2014 Thanks for the info, i have decided to just buy a double steering joint as they can cope with up 70 degrees angle so that should save moving the rack. Bloody expensive to buy from the US. I had all the other parts but the single one looked to be a bit tight on the angle so i hope this will solve it!! Andy I bought two of these last week, I think they were £30 + vat each http://www.steering-racks.co.uk/ujs/ Quote Link to comment Share on other sites More sharing options...
Julian Posted October 28, 2014 Share Posted October 28, 2014 (edited) If you are talking about the same joints as are used on the Manta column, I have a couple of them, used but excellent condition. Edited October 28, 2014 by Julian Quote Link to comment Share on other sites More sharing options...
611 Posted October 28, 2014 Author Share Posted October 28, 2014 I wish it was as i have a couple myself!! Due to the tight angle i need to get the steering column to take i need one of these. http://www.summitracing.com/parts/BRG-024949 and you don't seem to be able to get cheap ones or even ones over here? Andy Quote Link to comment Share on other sites More sharing options...
