1980 Cavalier Sportshatch - Manifold To Downpipe Gasket
Nigel Wilkins
The offset 4 stud manifold joint was only on the later 1800 Mantas as far as I know, as well as the mk2 Cav amongst others. Yours won't have a GTE manifold but the joint between the manifold and downpipe is the same for yours and the GTE as they're the same engine. Only difference between a carbed 1600 manifold and a GTE is that the carbed version is bolted to the inlet manifold to warm the air coming into the engine.
Still having trouble getting the right one, I have now ended up with 2 that are too small, like the small one in Mickfrads post up a bit but need the bigger one he has pictured! Is that the part number for the bigger gasket Mickfrad or are they both in the pack? Dog312fish that's one of the gaskets I now have but its too small...
Edited by Nigel Wilkins
