shooie811 Posted August 28, 2014 Share Posted August 28, 2014 Hi im swapping my 3 clock to 6 clock i did this years ago a cant remember how i did heres a pic of the connecter cheers chris Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 28, 2014 Share Posted August 28, 2014 Hi. You also need the small 5 terminal half round plug to fit the 6dial dash.pull out all the wires from the big round plug in your picture and re insert them as follows.looking at the plug with locating peg at top facing you they number 1 to 11 clockwise.1black/red.2black/white.3black/green.4brown/white.5blue.6brown.7new wire to oil pressure 2terminal sender unit.8blue/black.9blue/white.10blue/green(to oil pressure sender lamp terminal.11black.then on the small half round plug.with peg facing you count 1to5.only two wires here.number 3white.4new green wire to coil - side for tachometer. Quote Link to comment Share on other sites More sharing options...
shooie811 Posted August 28, 2014 Author Share Posted August 28, 2014 Cheers mate Quote Link to comment Share on other sites More sharing options...
