611 Posted September 18, 2013 Share Posted September 18, 2013 Ok im fitting a bigger alternator 70a off of a Frontera. Problem: Current bracket to short (see pic) im told Monza 3.0 (and maybe other 3.0 straight 6 engines) use a threaded adjuster. But i cant find pics or part numbers of bar and contacted GM6 spares who say that they use a bar but they dont have time to go and look for one? Any other ideas? i looked at generic alternator adjusters but dont know what the Monza one looks like to compare them to. Any help would be great. Thanks Andy Quote Link to comment Share on other sites More sharing options...
garymanc Posted September 18, 2013 Share Posted September 18, 2013 (edited) threaded bar with a rose joint on both ends http://www.migweb.co.uk/forums/projects-restorations/453445-craigs-xe-track-nova-45.html shows one done on a different car Edited September 18, 2013 by garymanc Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 18, 2013 Share Posted September 18, 2013 Another one of the bars with the long hole in, bolted to original and then a nut to space back to the new alt? Quote Link to comment Share on other sites More sharing options...
611 Posted September 18, 2013 Author Share Posted September 18, 2013 That could work as well. I think i will see if i can find one like in the picture as that might look a bit nicer and less bots to come undone the better :-) so if anyone wants a nice powder coated standard bracket make me an offer :-) Andy Quote Link to comment Share on other sites More sharing options...
rutts Posted September 18, 2013 Share Posted September 18, 2013 Peugeot 106 has a nice threaded bar to adjust tension on belt. thinking of this way for mine. Quote Link to comment Share on other sites More sharing options...
manta88 Posted September 18, 2013 Share Posted September 18, 2013 (edited) Try a shorter belt and use the same bracket If there is room for the alternator to move. Edited September 18, 2013 by manta88 Quote Link to comment Share on other sites More sharing options...
611 Posted September 18, 2013 Author Share Posted September 18, 2013 (edited) Not enough movement as only moves about 1/2 inch before running out of bar. Found the 106 one but looks like the offset needs to be much closer to the block, mine is too far out. found this which looks spot on, but is it worth £52+ vat for just the adjustor? me thinks not. http://sbdev.co.uk/Info_sheets/Alternators/Fitting%20SBD%20alternator%20adjuster.htm Might have to make my own! Andy Edited September 18, 2013 by 611 Quote Link to comment Share on other sites More sharing options...
611 Posted September 18, 2013 Author Share Posted September 18, 2013 This looks more like it :-) http://www.ashton-mobile.co.uk/old-skool-ford-parts.php http://www.ebay.co.uk/itm/Alternator-Bracket-Ford-Xflow-Crossflow-And-Pinto-Engine-Escort-MK1-Mk2-Anglia-/281160360995 not found anything for a vauxhall. Andy Quote Link to comment Share on other sites More sharing options...
garymanc Posted September 18, 2013 Share Posted September 18, 2013 http://www.ebay.co.uk/sch/i.html?_trksid=p3984.m570.l1311.R1.TR1.TRC0.A0.Xrose+joints&_nkw=rose+joints&_sacat=0&_from=R40 rose joints and some threaded bar would be cheaper Quote Link to comment Share on other sites More sharing options...
611 Posted September 19, 2013 Author Share Posted September 19, 2013 You could be right :-) Quote Link to comment Share on other sites More sharing options...
611 Posted September 29, 2013 Author Share Posted September 29, 2013 Just a quick little update as i hate it when you find a thread that never shows the final solution :-) I bought an adjuster from Harris performance for £25 it wasn't quite long enough for my setup at 140mm fully open, so i bought a female rose joint off ebay for £2 and used a bit of threaded bar and now all sorted and looks good as well ;-) Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted September 29, 2013 Share Posted September 29, 2013 Good work Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 29, 2013 Share Posted September 29, 2013 (edited) That looks nice, may have to do just that on my cossie Nice hose clamps BTW Edited September 29, 2013 by Kevin Abbott Quote Link to comment Share on other sites More sharing options...
611 Posted September 29, 2013 Author Share Posted September 29, 2013 That looks nice, may have to do just that on my cossie Nice hose clamps BTW Hey Kev, glad you like it Much easier than the old bracket setup :-) and those hose clamps are so easy to adjust and well worth the money There the Mikalor stainless ones. This was the site i got the banjo end from http://engineersmate.com and looks like it might be handy for a few other bits ;-) Andy Quote Link to comment Share on other sites More sharing options...
