Manta A Lower Steering Bush
dan9770
The part number is 90023940
and they show it on this site.
http://www.online-teile.com/opel/advanced_search_result.php?XTCsid=89093c950b60eaf99ceabd1e3d31aac9&keywords=90023940&x=15&y=9
not used them but they take paypal so you would be covered.
Andy
The part is for Ascona Manta/B......and do not exist..... (it happens to exist at 50 Euros.....to Spain)
http://imageshack.us/f/834/153xh.jpg/
the correct is 912360
http://imageshack.us/f/821/4w6q.jpg/
Edited by OPEL PARTS GREECE
Thanks-I'll give it a go Dan
Hey Dan
You could give these guys a try
http://www.vauxhall-car-parts.co.uk/
very helpful with stuff and i think they can cross ref old to new part numbers etc.. Dont just go on what they have on the website as i was after some parts not on the site and when i called them they had a look, called me back to tell me they had them :-) so worth a go.
The one i have the part number for is from the B and is batter than the old A one that was just a plastic bush with like a felt inner this one has bearings and is the one opel parts greece posted http://imageshack.us/f/834/153xh.jpg/ not sure what you currently have?
Andy
Hey Dan
All i know is i have the one in the picture and the part number i listed fitted on my A, normal A steering column and have had it on there for years (before the years it has been off the road!) and no problems at all. Just put a new one in i had been keeping for the rebuild as the other one got likked when they bead blasted the underneath. So i would say they must be the same. But a more knowledgeable manta boffin will be able to tell you for sure. Much better than those old ones as these have bearings in them.
Hope this helps. I can get a pic of mine if you need to see it more close up to compare like for like as its out while i finish a little welding near there and didnt want to melt it!
let me know if you want a pic or two.
Andy
Andy-
gone with the www.online-te. option.Item was 11euro to buy,but somehow 17 euro to send!I guess i dont have the option.They listed the later B series bush for the earlier A so that could be a good call.Prior to that I did try Vauxhall car parts with a phone call,then an e-mail but were unable to help.
Thanks for the info.
Dan
Hey Dan
Its getting quite hard to find some bits so. And as you say you are kind of stuck with what they charge unless you can find them on ebay. Which can be hard on the german one :-)
Here are a couple of pictures of the ones i have on mine.
http://www.theopelproject.com/wp-content/uploads/2013/05/IMG_20130521_093145.jpg
http://www.theopelproject.com/wp-content/uploads/2013/05/IMG_20130521_093139.jpg
Let me know how you get on.
Andy
Fits in fine, needs a little bit more of a push to get it in. If you have to pull it out be carefully as its easy to pop the two bits apart, then it's ball bearings everywhere as I have found out before :-) when it's in it's spot on and you don't get any play in the steering at the bottom like you do in the old ones when they get a bit worn!
Andy
I've just had my purchase amount refunded through PayPal from online-te,inexplicably, so I guess they're out of stock! Have tried a few leads but I guess I'm going to have to make that bank draft to dr. Manta....
