Single Wiper Conversion Scuttle Panel
  • Please log in to reply
3 replies to this topic
#1 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • PipPipPipPipPipPip
  • 1,227 posts
  • Gender:Male
Posted 30 January 2012 - 02:06 AM
I did this many many many years ago so it has some rust rash but is sound
The wiper holes have been removed and the middle one repositioned in the centre of the scuttle panel
The old holes were butt welded and lead filled, this item needs finishing ( as the pictures show unless you are reading this in braille )
The motor underneath is from a fiat uno if i remember correctly and may need something or other doing to the circuit board but if you contact Gary Watson, Mantamorfin, asifimbothered ( same dude) he will tell you what it was as i can't remember
£20 plus post or collect from my house in Weir NW England
Posted Image
Posted Image
Posted Image
#2 andyf21
andyf21
    Rekord
  • OMOC Members
  • PipPip
  • 57 posts
  • Gender:Male
Posted 30 January 2012 - 10:23 AM
Hi there just a little advise, how easy was it to remove the scuttle panel
#3 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • 1,227 posts
  • Gender:Male
Posted 30 January 2012 - 11:01 AM
It is all spot welded on so quite easy once you identify the spot welds you need to drill out.
The hardest part is putting a decorators scraper down the back of the spot welds on the windscreen bottom edge as it is 3 sections welded together and you only have to split one off. You put it in and hammer it across to break the bits that the spot weld drill misses.
#4 andyf21
andyf21
    Rekord
  • OMOC Members
  • PipPip
  • 57 posts
  • Gender:Male
Posted 30 January 2012 - 12:21 PM
Thanks for that will  save me a lot of time and hassle.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
