Manta With Redtop - 2000Rpm Tickover - Auxilliary Air Valve
  • Please log in to reply
2 replies to this topic
#1 GMC
GMC
    Kapitan
  • OMOC Members
  • PipPipPip
  • 159 posts
  • Gender:Male
Posted 24 January 2012 - 10:28 PM
Having recently transplanted a C20XE redtop into my Manta (see  http://forums.mantac...oupe-barn-find/   )
it's ticking over at 2000rpm.
Knowing the auxiliary air valve (under the inlet manifold) is the common culprit, I removed it, applied 12v straight from a battery charger and sure enough it was seized shut. 15min of WD40 and brake cleaner and all was well - I could switch on/off the charger and watch the slider open & close.
Thinking all was well I refitted it, but still ticking over at 2000rpm??
I removed it again and checked it on the charger.....still switching no problem.
I then checked the power at the terminals of the wiring harness connector - 12v available. When connected, the valve (very quietly) buzzes but wont open, its as though there is power, but not enough to open it.
With 12v at the connector, its unlikely to be an ECU problem? Even though the unit it switching perfectly using the battery charger, I'm wondering if its still dodgy when connected to the car?
I've proven the problem definitely lies with the Aux Air Valve, as I can clamp the hose closed at the air filter end and the tickover drops to a perfect 900rpm,,
Any suggestions would be appreciated.
ps, also changed the engine temp sensor, so not that
Edited by GMC, 24 January 2012 - 10:35 PM.
#2 novashed
novashed
    Rekord
  • OMOC Members
  • PipPipPipPip
  • 443 posts
  • Gender:Male
Posted 24 January 2012 - 10:31 PM
change that idle control valve they notoriuos as you say, had many a dodgy a one on various xe guise cars ive had
#3 Retro Power
Retro Power
    Kadett
  • OMOC Members
  • PipPipPipPipPip
  • 599 posts
  • Gender:Male
Posted 25 January 2012 - 01:20 PM
As above, common fault and they are not just open and shut, they maintain various positions. I have several if you need one.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
