Hey all,
Does anyone have suggestions for something that will give a bit of extra electrical juice?
The easiest and cheapest to sourcing option for me is the 60A out of a Astra mk2 (Kadett E).
How easily would that go into a standard A?
The wiring was updated and uprated a little while ago so I'm not worried about the extra current frying anything.
Manta A Alternator Options
Started by
Binnacle-ZA
, Jan 22 2012 09:22 PM
4 replies to this topic
#1
Posted 22 January 2012 - 09:22 PM
#2
Posted 23 January 2012 - 03:28 AM
Not sure if the Astra alternator will fit, if it does go on the bracket the pully might not be inline.
the best answer is the alternator off a twelve valve straight six, (senator,carlton etc) they are 95 amp, you will need the mounting bracket as well and tensioner, this bolts onto a manta CIH engine and is a much superior design.
#3
Posted 23 January 2012 - 08:56 PM
or you can use a 65amp from a senator (circa a to d reg) these use the same mount as the std 45 amp unit .
also a 55 amp from a carlton 2.2 will fit.
#4
Posted 24 January 2012 - 02:46 PM
Thanks for the reccomendations.
Probably should have said I'm in South Africa...
Rekords/Carltons and Senators are really difficult to find parts for (ie Alternator).
They do pop up every now and then, but like I said, astra bits I can find at my local breakers, whereas I'd have to go to Cape Town to search for rekords etc.
#5
Posted 24 January 2012 - 05:36 PM
Do you not have a local alternator specialist who can rewind your existing one to give more output?
Cheers
D
Cheers
D
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
