Manta 400 R Cosworth
  • Please log in to reply
13 replies to this topic
#1 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • PipPipPipPipPipPip
  • 1,226 posts
  • Gender:Male
Posted 22 January 2012 - 12:17 AM
As I can't find ( after plenty of searching ) my project thread and with the old one being all messed up due to it being an old thread I will start again :)
I bought the car 12 years ago and set about the task of buying and fitting a cosworth engine and box
Opel Manta coupe,  the best shell I have had in 20 years and owned by a lady and the car had only 40 thousand miles on the clock
Back in the day digital cameras didn't exist so I have no pics of it as it was :'(
Hey ho.....   cosworth engine added and t5 box
Posted Image
manta i240 bodykit from the best in the country( rallytech)
Posted Image
T5 box a bit long for the manta so I sierra tunnel added although I now may go back to a getrag 265 and manta tunnel :'(
Posted Image
Manta pcd is 4x100 and I wanted 5 x120 so hubs changed to monza with manta bearings custom made at a cost of 200 quid so I could pick and choose bmw rims
These are harge split rims
Posted Image
Other rims to consider are these which seem to fill the arch better
Posted Image
The roof on a manta is rubbish so I cut it off and added a non sunroof one
Posted Image
Posted Image
And lead fill
Posted Image
Manta brakes, deathwish so m3 discs and integralle calipers
Posted Image
RS500 intercooler tucked into nose
Posted Image
cage added
Posted Image
manta steering is always really heavy( honestly it can be a 2 hand job just to turn and that leaves no hands for stirring the box :-X)  on a lowered car so I added corsa b column power steering
Posted Image
Then I added EPS
Corsa b column
Posted Image
Remove the outer collapsable top part of the corsa bit
Posted Image
You are left with
Posted Image
Don't hit the end of the spline as I did or the spline end will come off
Posted Image
I will be putting a blob of weld on mine to hold the 2 parts together as the top part with the manta bit added will not collapse now anyway, the reference for the amount to stick out is 85mm for the top part
Posted Image
Take your manta column and remove the inside part
Posted Image
What I was trying to do was keep the columns the same length so the inner part was my reference point
Posted Image
Take the outside of the manta column and chop it into 3 pieces
Posted Image
Edited by Kevin Abbott, 22 January 2012 - 12:46 AM.
#2 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • 1,226 posts
  • Gender:Male
Posted 22 January 2012 - 12:48 AM
Giving away my mancona and seeing Johns project gave me a kick up the arse.
So.
Iv'e never liked the T5 and sierra tunnel... Yuk
Posted Image
Posted Image
After a little googling I found out the RS500 Touring cars used a Getrag box, the 265 :rolleyes:
I have a couple lying around so what the hell.
Posted Image
265 monza box, yea :D
Need to join the two
Posted Image
Ali adaptor ( cheers Cliff )
Posted Image
Cut big hole in T5 bellhousing
Posted Image
10 hours of measuring and measuring and measuring and swarf everywhere
Posted Image
That's just together, not bolted up yet, spigot not done
Spigot was a PITA, tried getting it out of the cossie ... Arrrrrghhhhhh, ended up welding a nut to the race and drifted it out
Posted Image
New oilite bearing fitted ( thank's Rutts ) after boiling it in oil
Posted Image
Posted Image
It went a different colour
Posted Image
Info, Sierra cosworth spigot bearing outer is 21mm, inner 14mm
Manta outer 21mm, inner 15mm
I needed a 21OD, 12ID
Posted Image
Lots of angle measurements later as I had built a stand for the YB to sit the engine at 4 degree to Exhaust and the box had to be level
Posted Image
Bolted up
Posted Image
Posted Image
Edited by Kevin Abbott, 15 February 2012 - 07:10 PM.
#3 johno
johno
    Kapitan
  • OMOC Members
  • PipPipPip
  • 119 posts
Posted 22 January 2012 - 05:35 PM
VERY NICE PROJECT!! :thumbup :) :)
#4 robah
robah
    Senator
  • OMOC Members
  • PipPipPipPipPip
  • 702 posts
  • Gender:Male
Posted 22 January 2012 - 06:29 PM
So this is the car Danny mentioned at the chrimbo function :rolleyes: . Nice to see someone taking as long as I am to get there ar5e in gear. :blink:
#5 danko_f4
danko_f4
    Kadett
  • Users
  • Pip
  • 4 posts
  • Gender:Male
Posted 14 February 2012 - 08:32 PM
very nice car
What is the rear diferencial
#6 opelmantagsi
opelmantagsi
    Commodore
  • Web Members
  • PipPipPipPip
  • 428 posts
  • Gender:Male
Posted 15 February 2012 - 12:15 AM
great effort so far, looks awesome. whats the plan with the engine mounts?
#7 peter evans
peter evans
    Kapitan
  • OMOC Members
  • PipPipPip
  • 135 posts
  • Gender:Male
Posted 15 February 2012 - 07:27 AM
hi kev its peter i bought the roof skin from you do you have a lsd for sale?
thanks peter
#8 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • 1,226 posts
  • Gender:Male
Posted 15 February 2012 - 07:33 PM
Post is a bit topsy turvy due to me not being able to add more pictures to the first bit
I now have a ' Martin' 400 kit for it and hope to bring the car home next week.
Loads of new stuff bought for it
Thank's to Rutts I have an original tunnel to go back into it too
You want the top outer part to be 180mm
Posted Image
That part slips over the inner of the corsa bit
Posted Image
These two parts will be welded together
Make room to get at the bolts
Posted Image
This will now take the manta multi switchgear and wheel in the same place as a standard car
Posted Image
Bottom part of the column
Take the inner shaft from the manta and split it then cut the bottom part down to 315mm
Posted Image
Posted Image
Take the bottom part of the outer of the manta column and bolt it to the floor, mine hasn't got a bearing in as it will be blasted and a new one fitted
Column will now bolt into place as the original
Posted Image
Posted Image
It fits in the bay as the standard one does
I got the column myself so removed lots of wiring and got the fuseholer that was standard in the car
Posted Image
I settled on the 4ha mega axle as used by scimitar, jaguar and aston martin as it is unbreakable ;)
Pic is a 4ha compared to a 400 type axle
Posted Image
I removed the axle from a scimitar gte and it was a 4 hour fight, at the end of it the bloke who owned the yard felt sorry for me and carried it to my volvo :)
PCD on the hub is 4x108 and I need 5x 120 so I went out and got a set of geometry school stuff, plotted the center of the scimitar and the bmw and transfered it onto graph paper
Posted Image
So after a plug on one hole
Posted Image
And a weld then grind flat
Posted Image
The 5x120 can be drilled
Posted Image
I had to add a milled surface for the back of the stud parallel to the hub so I got a counter bore drill
Posted Image
It did this
Posted Image
Studs in and ready for the wheels
Posted Image
I am removing the links from the 4ha and replacing them with 400 type ones
Posted Image
This is the xjs axle that is hiding the 4ha LSD. The only axle I have ever had to take apart with a sledgehammer
Posted Image
Posted Image
Sorry Peter, i sold the rebuilt ZF I had on it.
Engine mounts are done,
http://img.photobuck...er/85c7b08c.jpg
Other side harder to see as I had to use a cosworth 4x4 oil filter extension
http://img.photobuck...er/9fc4de09.jpg
#9 opelmantagsi
opelmantagsi
    Commodore
  • Web Members
  • PipPipPipPip
  • 428 posts
  • Gender:Male
Posted 15 February 2012 - 10:07 PM
cool, so what is the plan for between the mount on the block and the fixing point on the sub frame? rubber bobbins or solid mounts?
#10 Danny D114BCW
Danny D114BCW
    Senator
  • Users
  • PipPipPipPipPip
  • 712 posts
  • Gender:Male
Posted 15 February 2012 - 10:16 PM
Sorry to crash this thread for a second but Peter, Gripper do a good slippy diff thats based on the ZF type. Kev car looks great and its been a great shelf for nearly 10years i have known ya haha but no it does look good.
#11 Ivan1969
Ivan1969
    Kadett
  • Users
  • Pip
  • 7 posts
  • Gender:Male
Posted 16 February 2012 - 05:36 PM
super
Posted Image
Posted Image
#12 garymanc
garymanc
    Manta Guru
  • OMOC Members
  • PipPipPipPipPipPipPipPip
  • 2,799 posts
  • Gender:Male
Posted 17 February 2012 - 01:00 AM
thanks peter
http://totalopel.com...ead.php?t=17620 in ireland
car is looking good kev,when will it be finished :ph34r:
#13 Kevin Abbott
Kevin Abbott
    Diplomat
  • OMOC Members
  • 1,226 posts
  • Gender:Male
Posted 17 February 2012 - 08:11 PM
For Billing ;)
#14 mickappy
mickappy
    Diplomat
  • OMOC Members
  • 1,332 posts
  • Gender:Male
Posted 17 February 2012 - 11:30 PM
which year kev;-).
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
