Edited by Manta again, 02 November 2011 - 07:02 PM.
Starting Problems
#1
Posted 25 October 2011 - 04:14 PM
#2
Posted 25 October 2011 - 04:41 PM
Edited by mantapaperman, 25 October 2011 - 04:44 PM.
#3
Posted 25 October 2011 - 04:50 PM
Edited by Manta again, 25 October 2011 - 04:57 PM.
#4
Posted 25 October 2011 - 05:32 PM
#5
Posted 25 October 2011 - 08:09 PM
I would take a look at the ignition. Initially it would sound like the fuel shut off valve in the carb is stuck . This should also be controlled. Take the top part of the carb off (it is easy to remove the 5-6 screws with a plain screwdriver) and see if there is gasoline with the floater. If not, take a look at the underside of the top carb part. There should be a small valve there activated by the floater to let gasoline into the carb when fuel level in the floatchamber gets low, and often this can get stuck in shut position.
If this is not the issue, i would take a look at the ignition. Is there any spark ? How good is the spark ? Distributer and cap are not expensive parts, so change them, you can also test the coil (use another one from another car or something and see if this changes anything). Last but not least take a good look at the plugs. Are they wet with gasoline after an attempted startup there is propably not any spark.
Actually it is very easy to determin the problem you have. If the carb works (wet plugs) your problem is no spark or bad spark.
#6
Posted 25 October 2011 - 08:14 PM
#7
Posted 25 October 2011 - 08:17 PM
If so take the feed pipe from the pump and stick it in a can of fuel and check to see if it still splutters
No splutters mean its a problem with the pipe from the tank to engine bay, or possibly the pickup pipe in the tank.
However if it still splutters then the problem is still at the front end.
I have a vauge memory of one car i had that had fuel supply issues and someone had fitted 2 spacers behind the fuel pump so the plunger wasn't moving enough.
The standard pipe from tank to engine bay is a moulded plastic item that isn't the best.
It can get crimped and caught by things restricting the flow of fuel, also a tiny hole in the pipe won't necassarily leak fuel but will suck air when the fuel flows past.
#8
Posted 25 October 2011 - 08:29 PM
Also chances of having 2 different carbs with the same float problem are very small so more likely the problem is elsewhere.
When i helped start the car at Billing there was a good spark just no fuel at the carb, hence the addition of fuel direct down the carb and she fired straight up.
#9
Posted 25 October 2011 - 08:32 PM
Have you checked that the fuel tank is venting? like try it with the filler cap off.
Edited by Julian, 25 October 2011 - 08:35 PM.
#10
Posted 25 October 2011 - 09:26 PM
#11
Posted 26 October 2011 - 12:43 PM
If you still have a problem after that, as has been said look at the ignition system. I had to replace a wire to the coil because of an intermittent starting/running fault.
Best of luck
Dave
#12
Posted 26 October 2011 - 09:36 PM
Manta again, on 25 October 2011 - 09:26 PM, said:
perhaps its time to call it a day
#13
Posted 26 October 2011 - 09:53 PM
#14
Posted 26 October 2011 - 11:00 PM
monzta, on 26 October 2011 - 09:53 PM, said:
Manta again, on 25 October 2011 - 04:14 PM, said:
#15
Posted 26 October 2011 - 11:02 PM
.......unless the coil or leads are breaking down when hot and the time it takes to get some fuel to pour is enough for it to cool.
Some of the connections on the ignition amp can be troublesome, especially the green piggy back that works the rev counter.
#16
Posted 27 October 2011 - 02:24 PM
#17
Posted 27 October 2011 - 03:30 PM
But i would suggest that you use the Weber, it is better in every aspect. The varajet carb you can poor gasoline on and wee on the ashes and nobody will cry over that
If you have iddle problems (2000 rpm) with both carbs i am almost 100 % sure that you have an airleak somewhere.. Or some sort of ignition problem..
#18
Posted 27 October 2011 - 03:57 PM
I installed a clear in line filter between the pump and carb and ran the engine with both old and new pumps fitted. The petrol is as clear as water!!! The rate of fuel delivery doesn't seem to be great certainly never enough to even part fill the small filter and is also inconsistent with both both pumps regardless of engine speed. If the lobe on the cam was worn I'd expect to see no difference in fuel volume. I also ran the car with fuel filler removed it made no difference to fuel delivery thereby eliminating a blocked vent issue
So all in all either the tank is full of crap but its not coming down the fuel line or the fuel line is partially blocked. Its just wiered that if you drive the car every day its OK 90% of the time.
Should I blow the fuel lines back through into the tank or remove them and do it, actually I will probably go and get new lines tomorrow. anyone got a spare hatch tank for me to try?????
Another more radical solution is bin the entire engine and go C20xe as some one said it could easily be done in a day with an 1800 car?? Anyone got a complete running setup from a manta and could guarentee my wife it could be done in a day
Edited by Manta again, 27 October 2011 - 04:06 PM.
#19
Posted 27 October 2011 - 04:20 PM
On my Manta these wires age hardened and went brittle breaking down when hot. Just cut back to "good" wire and run a new length in.
Another suggestion is the ignition module available on eBay: http://www.ebay.co.u...=item587e730660
You will get there in the end.
Edited by dog321fish, 31 October 2011 - 03:33 PM.
#20
Posted 27 October 2011 - 04:29 PM
Another suggestion is the ignition module available on eBay: http://www.ebay.co.u...=item484281d3d3
Not sure its an electrical problem as the car always starts if you pour fuel into the carb, but will check the wiring tomorrow. thanks for the thought.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
