mint, on 26 April 2011 - 05:23 PM, said:
Hello,
I'd like one of these kits please. I have an XE and and 1800 box, does this include everything to go in between?
Sorry Mint missed the post
Yep it's all you need, 3 piece clutch
johnboy, on 09 May 2011 - 12:13 PM, said:
Maybe a daft question??? If the friction plate is bigger then is the cover also bigger in diameter meaning i have to drill and retap the flywheel, not a problem if i do , just wondering.
1.8 gearbox is on its way, looking for a redtop at the mo and then will be in touch for a clutch kit, slowly gathering the bits ready for a redtop conversion on the A series over next winter, cheers for now John
Pressure plate fit's straight onto xe flywheel and the friction plate is nice and snug inside it, no messing about needed
Update on clutch kits
I'm having problems with the clutches at the mo due to a shortage of xe pressure plates, the problem is i need to supply a used plate to my supplier before i can get get a new kit from him.
If you can you get your used xe pressure plate to me then i can supply you with a kit.
I recommend myhermes parcel delivery and it will cost you about 6 quid to send it to me.
I have supplied about 10 clutch kits recently and my supplier has run out
Regards
Kev
