After a lot of pushing and shoving I managed to get her into the daylight for the first time since 2005.
The 18 months of standing without movement hasn't done the brakes any favours!
After a bit of work I managed to get the pads out and clean up the discs enough just so that I can get the car to move about easier. Whilst there I had a good look at the ball joints and track rod ends to check there condition. The rubber boot on each track rod had a split in it. No problem I have been buying up spares on ebay when ever there was something worth having. It would be a simple job to put the new ones on!! Removal was pure Haynes text book stuff. However when I tried putting the new track rod on the passenger side it was really difficult to start and after one turn it would stick. On close inspection of the thread on the end of the steering knuckle it became apparent that the last time this was track rod was replaced the monkey responsible had managed to cross thread it! Never mind I have a replacement steering knuckle (ebay again) only to fit these you to remove the steering rack in order to be able to bend back the tabs on the locking ring. More time required to carry out the work.
Other work that needs to be carried out before going for the MOT is some welding to the swan neck on the drivers side and a small blister on the floor pan next to the sill. One possibly 2 headlamps need replacing the silvering has gone rusty. One of the screws holding down the distributor cap has rouded out (sh*t) making it tricky to checks point etc. Has anyone tried the Accu spark system on their Manta? Might go for that if it works but £30 seems cheap for an electronic system! The cylinder head could do with converting to an unleaded head. Oh and clean the inside yuk!!
When funds and time allow I want to replace the exhaust system with a stainless system, upgrade the brakes. I'm sure I will find plenty of things to keep me busy with. My wife (I love her so much) wants us to get another A so we can use that for when the existing one is not on the road. Would be interested in A with straight engine in it, could be the only way I'll have the opportunity to own a TE2800 even if it was a replica.
