Titan Motorsport Traction Master Lsds
TJM
Hello to all,
I can now supply new plate limited slip differentials for the Manta/Kadett/Ascona/Chevette HS rear axles. Manufactured by Titan Motorsport:
Improved Driveability
Titan’s unique sintered clutch plate coating, Sintrak™, ensures the unit increases load to the slipping wheel in an
extremely smooth and linear manner, improving feel and driveability.
Increased Torque Transfer
Titan’s Sintrak™ coated clutch plates are able to transfer significantly more torque across the rear axle to the wheel
with higher levels of grip than steel plated differentials, helping you get more power down when exiting a corner.
Extremely Low Clutch Plate Noise, Vibration and Harshness (NVH)
Due to the frictional characteristics of steel, limited slip differentials that have steel on steel clutch plates can
experience high levels of NVH in use. The advanced friction characteristics of Sintrak™ significantly reduce, and in
some cases eliminate, these problems.
Rigorously Tested
Titan differentials have been developed in house at Titan Motorsport and tested under the harshest of conditions,
racking up hundreds of hours on the road and racetrack.
Bespoke Setups
Traction Master differentials are available in a variety of set-ups to suit your vehicle. Our sales staff will be able to help
you pick the right ramp angle and pre-load options for your application.
Wear Resistant
The unique Sintrak™ coating has extremely good durability, which ensures plate wear and the associated pre-load
drop off is kept to a minimum, and any wear that does occur is consistent and doesn’t ruin performance.
Quality
Titan components are designed and manufactured using the latest CAD/CAM technologies from the highest quality
materials available, all to ISO 9000 standards.
Retail price is £822.50 but I can do a special introductory offer of £665.00 plus £15 P&P. Made to order so anything from 10-21 working days at the moment but would have to confirm if anyone wished to order.
Regards
Tim
You are probably looking at 2 weeks maximum but give me an idea of when you require one and if not too long I am sure we can work something out.
Regards
Tim
Email sent last night, look forward to hearing from you.
Cheers
Brendan
  • 5 years later...
